Dynatrace is showing this messagae, but I checked my IIS and everything is working well in it.
Did you check the process network metrics charts? How long was the problem open?
Hi, I have the same problem too. What analysis can I do?
Hi, I am new to Dynatrace and I am facing exactly same issue. Do I need to worry about it .?
@Wolfgang B. Can you help us to resolve this problem.
If your application is not in use no. You need to check host network threadsholds
As Felipe said, if .NET iis application is not in use, app pool is suspended. In such case application process can have connectivity error. If your host has no connectivity problems and network traffic is fine, than there is nothing to worry about it. If this happens in the same time every day you can configure maintenance window to suspend problems. But be aware that will suspend all problems related to entities picked for this window.
@sebastian k. Thank you so much. Your help is appreciated.
hello sir,
currently I am also facing this issue this alert has happen 3day already, but by we checking with relate team service is working normal.
Is there anyway that we can deep down the issue?
