Problems app - how to find impacted entities
Is there a way to find the impacted entities directly on the new app?
As we’ve that by default in classic -
Munawar
I cannot see that option neither. Maybe it might be a product idea.
An alternative would be using DQL in a Notebook / Dashboard.
Best regards
Unfortunately there is no option for it yet, but the ‘Under maintenance’ filter also just got added recently so there is hope ;). The ‘Affected’ filter is unfortunately ony for defining a number (minimum, maximum, etc.) of affected entities, not the actual names. I have created a product idea for it today, maybe you would like to upvote :slightly_smiling_face:
Add an “Impacted Entities” or “Affected Entities” filter to the new problems dashboard - Dynatrace Community
