I am having this exact same problem just started in our system recently as well. I’ve combed through all the setting and even updated the OpsGenie integration to V2 but still alerts are not auto closing. Hopefully a resolution can be found, I will keep looking on my end.
we having this exact same problem too. it was working a few days ago. We didn’t change any configuration. I think this problem occured after server last update.
I sent a ticket to Dynatrace support. The answer is that Atlassian depracated the V1 of Opsgenie integration with Dynatrace and is pushing the use of their new integration using a webhook in a Custom Integration.
The advice of Dynatrace support was to follow Opsegnie documentation :
And to make sure to :
- check the box “Call webhook if problem is closed”
When I add “PID”:“{PID}” to the json it strips responders/owners from the alert so it goes to Opgenie but doesn’t trigger actual alerts, when I removed the “PID”:“{PID}” I get the alert notifications. Did you also see this behavior?
Yes, using custom integration and my JSON is identical, I deleted and recreated the integration and I get the notifications in OpsGenie but it is not assigning an owner or responder even thought the team is added to the integration I am not sure what is occurring. I tried tying it to the escalation process and the team both act the same and are not triggering an alert.
I think I just figured it out, even though the webhook integration is setup the alerts are coming in via the Default API which was not assigned to a team.
