Process group availability monitoring
Hi Team,
Is there a way to fetch list of process groups and validate availability monitoring is turned on for them?
Srikanth
You need to extract the info via the entity API.
Use the entity selector type(“PROCESS_GROUP”) and iterate to obtain the desired information.
You can get all process groups using entities API . You need to filter by process group.
But not sure if that API returns that flag enabled or not.
If not, another option woul be download all configuration using Monaco and finding API “builtin:availability.process-group-alerting”.
Then, you can filter by “alertingMode” in all JSON files downloaded and you can find process group ID in config.yaml.
I hope someone can provide a better or more automatic way.
Best regards
Best regards
