We are trying to separate process groups into several depending on Software AG install path property. We are really missing regex funcionallity on Advanced Detection Rules configuration.
Right now, we have a cluster with two nodes and four process flavours clusters. Dynatrace is detecting all of them as a single process group. Installation path are like this:
If there is no other value in the process metadata that correlates to the version difference, you might have to add another java variable to your configs to be used by the Dynatrace process group detection (if you are able to do this).
The key is to find the correct property that has the installation path like “Java JAR path”, “Command line args”, or maybe “EXE path”. Then you can set “Delimit from” to /profiles/ and “Delimit to” to / ? Uncheck the “Ignore numbers” option.
Another option is to copy the command line args into Vim, do a string replace of the space character with a carriage return, %s/ /\r/g, and see if anything in the command line args can be used to identify instances.
Installation path is an available option while configuring a new Advanced rule. Main problem is that we don’t get a configuration, by using ‘Delimit from/to’ options to ignore the first number, but not the rest:
