Process Level Traffic Alert
Dear All,
Is it possible to create an alert in case the process does not receive any traffic for a certain time? If Yes
What are the best practices to achieve?
Babar
You have these process group traffic metrics → Built-in classic metrics — Dynatrace Docs
You can create a metric event using those metrics.
Best regards
Hello @AntonPineiro
Thank you. I am getting lazy enough :slightly_smiling_face:
Babar
