I’m trying to create a timeseries tile that presents a Process Memory /CPU usage per host, and filter it according to a variable called “ServiceId”. for example :
I use a variable called “ServiceID” and i choose “Service-123”. I want to receive a tile for the CPU and another one for memory usage of the Service’s process, spited by the hosts it is running on. so if it runs on server A and Server B i will get a tile with 2 graphs showing the memory usage of the service’s process (same for CPU).
i tried to create several DQL for that but couldn’t get to a correct one. i’ll be glad for advise and code examples.
