Process monitoring - cron, NTPD, Syslogd, Xinetd
Is Dynatrace have capable to monitor the cron,NTPD,Syslogd,Xinetd Processes,if yes then how to monitor it
You can custom define services and processes for detection if they are not detected out of the box. This can be done here: Process deep monitoring — Dynatrace Docs
If you’d like to put in a Product Idea, you can do so here: https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
