Process Monitoring
Hi Team.
I’d like to ask some question about ‘Process Monitoring’
In figure I attached,
it show a high re-transmission rate, and low connectivity one process.
So I want know what these two factor(re-transmission,connectivity) means in dynatrace.
for example, connectivity means that connectivity between dynatrace and the process.
and please let me know what ‘;High re-transmission rate and Low connectivity’ means in dynatrace.
Thank you in advance
Connectivity means connectivity between your processes, not connectivity between dynatrace and the process.
Please take a look on this article: https://www.dynatrace.com/support/help/shortlink/p…
Re-transmission is the resending of packets which have been damaged or lost.
You can choose the process to see it`s own re-transmission rate, see example below.
Also you can try Analyze process connections:
You can analyze quality of connection for every entity.
It is great function and possibility of dynatrace processess connectivity analysis.
Alexander
