Process running on a windows machcine is not detected by Dynatrace
We have application deployed on windows server. Looking at task manager, I could see the application processes running but same processes dynatrace is not detecting. There is SMTP service running and I could see the process for that as well but same is not detected by dynatrace.
What could be reason for not detecting all processes.
Hello Suresh K. ,
Processes are detected by Dynatrace based on conditions mentioned in the below link
https://www.dynatrace.com/support/help/infrastruct…
Is your processs meeting any of the criteria listed in above link?
HImanshu Mor
Thanks Himanshu.
My process belongs to c++ technology. Others processes from the same application detected under type others. so I was wondering why it was not detected. However , I added it manually by process detection rule.
