Hello, can you tell me why in Dynatrace SaaS the processes discovered by oneagent with websphere or jboss technology are detected and named as localhost or default-host
Hi José,
Dynatrace attempts to find a Process-group name by using e.g. the environment variables and some logic. It is very well possible that you defined a JBoss installation with the cluster-name or instance-name default-host (or maybe that name is part of jour jboss-homedir).
You can adapt the Program Group Names with some help of the online documentation: https://www.dynatrace.com/support/help/monitor/pr…
