Property to monitor the injection state of OneAgent using DQL.
Good morning comunity, I hope you’re all well. Is there a process property available in DQL that allows me to identify processes that have not been restarted yet, in order to enable in-depth monitoring?
Hi @YeudyGomez ,
I had a similar question but couldn’t find any direct option. However, I did come across some alternative solutions that might fit our use case. : https://community.dynatrace.com/t5/Alerting/Create-a-list-of-unmonitored-processes/m-p/241649 May be you can also have look
However, if anyone has an idea on how to retrieve it using DQL, that would be great.
Akhil Jayendran
