Proxy setting in Dynatrace
@Radoslaw S. Where to define these? So I checked on Dynatrace settings → Internet connection as you suggested and I see there is a proxy server configured already.
Initially we integrated with Slack which is external (outside my corp network) so it worked perfectly fine. Then we targeted to integrate with Netcool which is internal (inside my corp network and doesn’t require proxy) and it didn’t work.
We raised a support ticket to DT and they asked us to change these settings. We did that, restarted but it didn’t work.
What else do i need to define here? If you could guide me it would be very helpful.
<server/conf/config.properties> <br>[http.client.external] <br>proxy-non-proxy-hosts = <a rel="noopener noreferrer nofollow" href="https://myntlserver.com/probe/dynatraces" target="_blank">myntlserver.com/probe/dynatraces</a>
Shashank, can you please open a support case? We’ll take a closer look at you configuration. Also I can confirm you will be able to configure that in UI in version 1.206.
@Radoslaw S. I have got it working. I have followed what you have said and it starts working now. I can now connect to both Netcool and Slack.
Thanks again for your help and support.
I’m very glad to hear that!
