Public ActiveGate - what URL does it share outside for Synthetics monitoring?
Dear all, do you know what URLs Dynatrace Managed shares outside for use Synthetic Monitor?
Thanks in advance.
Emiliano
Hi Emiliano,
If you go to the Public Security Gateway page on the Cluster Management Console you’ll see the section Publicly available IP address - which should contain the IP address that the external Synthetics use to reach your Dynatrace Managed instance.
Sia
