Public endpoints for the Cluster ActiveGate
In the Dynatrace Managed deployments, there are sometimes requirements to filter the communication from the wilds of the Internet to the Cluster ActiveGates to comply with security policies. If your deployment uses some sort of web application firewall or load balancer being able to filter out certain URLs, you are able to filter out certain functionality just based on the URLs.
In the table below there is a list of the functionality that is covered by the Cluster ActiveGate and URL paths with HTTP methods the functionality requires.  Content types indicate the data types being transmitted to your Managed cluster using the Cluster ActiveGate.
Please note this is indicative and may change in upcoming ActiveGate releases without further notice.
<tenant> - is the environment ID (UUID) for such the regular expression is:
[0-9a-fA-F]{8}\-[0-9a-fA-F]{4}\-[0-9a-fA-F]{4}\-[0-9a-fA-F]{4}\-[0-9a-fA-F]{12}
Cluster ActiveGate endpoints
FunctionalityURL path starts withHTTP methodsContent type
Mission control check/rest/state
  • GET
Mobile application monitoring/mbeacon/
/dtmb/
  • GET
  • POST
text/plain
OneAgent communication/communication
  • HEAD
  • POST
application/octet-stream
API endpoints/e//api/
  • GET
  • POST
  • PUT
  • DELETE
text/plain
application/json
Dynatrace mobile app
(latest version)
/e//api/v2
  • GET
application/json
(legacy version)
/e//api/v1/mobile/settings
/e//api/v1/mobile/info
/e//api/v1/mobile/problems
/e//api/v1/mobile/problem/
  • GET
application/json
Accelerated Mobile Pages/ampbf/
Agentless monitoring/bf/
/jstag/managed/
  • GET
Browser Extension/e//api/v1/browserextension/config
  • GET
application/json
Synthetic/beacon/synthetic/
/beacon/synthetic/httpResults/
/beacon/synthetic/browser/
/beacon/synthetic/screenshot/
/beacon/synthetic/multi-protocol/
 /beacon/synthetic/credentials/
  • GET
  • POST
@Julius_Loman,
This is beautiful information! Securing access is a must in today’s environments. I believe this should be included in the Dynatrace documentation.
This is a great list, can I add 1 more for Synthetic? If you have screenshots stored in the cluster, rather than s3, you will, also, want
screenshots /beacon/synthetic/screenshot/<tenant>
Perfect! My list is still just “discovered”, let’s make it collaborative.
Hello @Julius_Loman
Great work!
Babar
Added a couple more Synthetic endpoints.
Multiprotocol monitor beacons
/beacon/synthetic/multi-protocol/<tenant>
For Credential vault updates by HTTP Monitors
/beacon/synthetic/credentials/<tenant>
In the row with the endpoints for Dynatrace mobile app there are brackets saying “legacy version”. Are there any endpoints that are newer? Does anyone know if there is any update to these Dynarace Mobile App endpoints or are they still used?
Many Thanks,
Petr
Hello @PetrVlacil ,
The old Dynatrace Mobile App only uses those endpoints. The newer app uses common Dynatrace v2 endpoints. For example, /api/v2/problems.
Thanks @Julius_Loman
Very Useful Content.
