Public facing status dashboard?
We would like to have a status dashboard for our services showing green/yellow/red availability (similar to Atlassian’s statuspage.io). A single service may consist of databases, multiple docker containers running on different hosts, a web server etc.. There are also background services we would like to display that have no web front end.
Is there a way we can leverage Dynatrace for this purpose, and if so what would be the best practices? Should we group components of service using tags, or push custom metrics with our definition of availability using a custom Dynatrace plugin? We could use the Dynatrace API to read metrics out into our own dashboard service.
Has anyone had experience setting something like this up, or is this not a good use case for Dynatrace?
Hey David… When reading your question I thought you might like our “Blinking lights tiles”. See here:
https://www.dynatrace.com/blog/optimize-dashboard-…
Does it help a bit?
has anyone tackled this issue? I’m looking at status.io vs statuspage.io but my question is the same
The answer to your question is: “RAG status for Apdex dashboard tile”
single value tiles => background color, thresholds for states as well as heatmaps (state over time)
Configure and use a heatmap visualization in Dynatrace
Configure and use a single-value visualization in Dynatrace
It looks like the link to the Configure and use a heatmap visualization in Dynatrace no longer works:  Configure and use a heatmap visualization in Dynatrace — Dynatrace Docs.
Can you provide an updated one if there is one?
Is this what you’re looking for? Configure and use a heatmap visualization in Dynatrace — Dynatrace Docs
Yes, Thank you.
