I am using trial version of Dynatrace for testing performance of my application.In multidimensional analysis for analyzing the response time drill down of my application, I checked multiple pure paths and in each of them I see 80-90% of time under Others in the Execution breakdown.If I check the code level, I see the response time is 4.72s, out of which 954ms is CPU time, 133ms is Suspension and rest 3.08s is in “OTHERS” for which no drill down is available.
How can I drill down further to check what exactly this “OTHERS” is? Or how can I optimize it?
I think that it is not possible.
Best regards
You can’t.
In distributed traces, the term Other refers to situations where Dynatrace is unable to provide a breakdown.
Other is the time left after subtracting the other components you see in the distributed traces.
Radek
