Good afternoon all, I am trying to setup a python 2.0 extension and every time I initialize the workspace I get this error.
2024-04-26T21:23:49.993Z [ERROR][dynatrace-extensions.initWorkspace] Unexpected error: Traceback (most recent call last): File “c:\users\aab0142\appdata\local\programs\python\python38\lib\runpy.py”, line 194, in _run_module_as_main return _run_code(code, main_globals, None, File “c:\users\aab0142\appdata\local\programs\python\python38\lib\runpy.py”, line 87, in _run_code exec(code, run_globals) File “C:\Users\userid\AppData\Local\Programs\Python\Python38\Scripts\dt-sdk.exe\__main__.py”, line 4, in <module> File “c:\users\userid\appdata\local\programs\python\python38\lib\site-packages\dynatrace_extension\__init__.py”, line 11, in <module> from .sdk.extension import DtEventType, Extension File “c:\users\userid\appdata\local\programs\python\python38\lib\site-packages\dynatrace_extension\sdk\extension.py”, line 85, in <module> class CountMetricRegistrationEntry(NamedTuple): File “c:\users\userid\appdata\local\programs\python\python38\lib\site-packages\dynatrace_extension\sdk\extension.py”, line 88, in CountMetricRegistrationEntry dimensions_list: list[str]TypeError: ‘type’ object is not subscriptableI have generated new certificates and also published them to dynatrace. I still get the same error. I would also like to add that I am using a Dynatrace Managed Env and had to add the flag “disableSSLVerification”. Can someone please help asap! Thank you!
