Python 2.0 extension
I recently tried to create a python based extension, and everything went fine, resolved many issues but during the deployment I see the below messages in the log file
<em>2024-07-03 19:18:18.245 UTC [0000049c] info [native] Rejected fastcheck for task f_7232207845354319405236535 -</em><br><em>2024-07-03 19:18:18.599 UTC [000003a9] info [native] Fastcheck f_7232207812345245236535 for datasource python ended with code -1: N/A</em>
Also I see this message, not sure if it is a warning or error as it is confusing.
<em> error: WARNING: pyjwt 1.1.0 does not provide the extra 'crypto'</em>
But in other line it mentioned that the versions are satisfied
Requirement already satisfied: PyJWT<2,>=1.0.0 in /var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/custom_dt-gen2-powerbi-utility_0.0.1/lib/python3.10/site-packages (from PyJWT[crypto]<2,>=1.0.0->msal->dt_gen2_powerbi_utility) (1.1.0)
Also in the console it printed below error message
“Failed to assign monitoring configuration to ActiveGate. Reason:”
But no Reason was provided.
All worked locally with the VSCODE extension but failed during the activation.
Any help would be highly appreciated.
I’ve come accross the same issue, are there any updates on this?
Kind regards
Workaround for me was to avoid msal and azure-identity  libraries and used only requests module to make it run.
