I understand there is an issue where I can’t use later versions of python(I have 3.12.X installed). I work at a bank and I can’t go back to older versions.
please advise when this can be fixed. I am trying to make a custom extension.
Error:
Python 3.10.X is required to build extensions, you are using sys.version_info(major=3, minor=12, micro=3, releaselevel=‘final’, serial=0)
