Dear all,
I don’t know where or whom do I need to ask about this issue so I’m asking it here. Quite a few times I ran into the situation where the log entries which should be “WARN” or “error” appears only as info. An example:
{"level":"info","ts":"2026-06-03T09:43:40.802Z","logger":"oneagent-url","msg":"installing agent from url"}
{"level":"info","ts":"2026-06-03T09:43:40.802Z","logger":"oneagent-url","msg":"installing agent","target dir":"/data/codemodules/1.335.58.20260423-145051"}
{"level":"info","ts":"2026-06-03T09:43:40.802Z","logger":"oneagent-url","msg":"downloading specific OneAgent package","version":"1.335.58.20260423-145051"}
{"level":"info","ts":"2026-06-03T09:44:40.805Z","logger":"oneagent-url","msg":"failed to get available versions","err":"Get \"https://dtmanaged.uniqa.hu/e/885d5d3f-f427-4b9b-a0ff-880fafb716b1/api/v1/deployment/installer/agent/versions/unix/paas?flavor=multidistro&arch=x86\": dial tcp 10.178.109.6:443: i/o timeout","errVerbose":"Get \"https://dtmanaged.uniqa.hu/e/885d5d3f-f427-4b9b-a0ff-880fafb716b1/api/v1/deployment/installer/agent/versions/unix/paas?flavor=multidistro&arch=x86\": dial tcp 10.178.109.6:443: i/o timeout\ngithub.com/Dynatrace/dynatrace-operator/pkg/clients/dynatrace.(*dynatraceClient).GetAgentVersions\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/clients/dynatrace/agent_version.go:93\ngithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url.Installer.downloadOneAgentWithVersion\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url/download.go:57\ngithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url.Installer.downloadOneAgentFromURL\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url/download.go:21\ngithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url.Installer.installAgent\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url/installer.go:119\ngithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url.Installer.InstallAgent\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/injection/codemodule/installer/url/installer.go:77\ngithub.com/Dynatrace/dynatrace-operator/pkg/controllers/csi/provisioner.(*OneAgentProvisioner).installAgent\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/controllers/csi/provisioner/install.go:34\ngithub.com/Dynatrace/dynatrace-operator/pkg/controllers/csi/provisioner.(*OneAgentProvisioner).Reconcile\n\tgithub.com/Dynatrace/dynatrace-operator/pkg/controllers/csi/provisioner/controller.go:139\nsigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).Reconcile\n\tsigs.k8s.io/controller-runtime@v0.21.0/pkg/internal/controller/controller.go:119\nsigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).reconcileHandler\n\tsigs.k8s.io/controller-runtime@v0.21.0/pkg/internal/controller/controller.go:340\nsigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).processNextWorkItem\n\tsigs.k8s.io/controller-runtime@v0.21.0/pkg/internal/controller/controller.go:300\nsigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).Start.func2.1\n\tsigs.k8s.io/controller-runtime@v0.21.0/pkg/internal/controller/controller.go:202\nruntime.goexit\n\truntime/asm_amd64.s:1693"}
{"level":"info","ts":"2026-06-03T09:44:40.805Z","logger":"oneagent-url","msg":"failed to install agent","targetDir":"/data/codemodules/1.335.58.20260423-145051"}
{"DynaKube":{"name":"uniqak8sdt","namespace":"dynatrace-operator"},"controller":"provisioner-controller","controllerGroup":"dynatrace.com","controllerKind":"DynaKube","error":"Get \"https://dtmanaged.uniqa.hu/e/885d5d3f-f427-4b9b-a0ff-880fafb716b1/api/v1/deployment/installer/agent/versions/unix/paas?flavor=multidistro\u0026arch=x86\": dial tcp 10.178.109.6:443: i/o timeout","level":"error","logger":"main","msg":"Reconciler error","name":"uniqak8sdt","namespace":"dynatrace-operator","reconcileID":"107e5209-bec2-4596-8a7e-21c92599e393","stacktrace":"Get \"https://dtmanaged.uniqa.hu/e/885d5d3f-f427-4b9b-a0ff-880fafb716b1/api/v1/deployment/installer/agent/versions/unix/paas?flavor=multidistro\u0026arch=x86\": dial tcp 10.178.109.6:443: i/o timeout
This is from the csi-driver pod’s provisioner.log file.
I think that the fact that this entry is shown as info not warn or error makes debugging and problem resolving much harder and takes much more time.
Can You suggest to whom do I have to report this?
Or am I wrong about it?
Regards
Peter
