I have exhausted everything I know about user Tags and no joy.
What do we use for react frontend (web browser) with nodejs backend. Also please give example.
I am seeing user actions and distributed traces but cannot get user Tags to work.
I have asked developer to try this from another post for Mobile
“this is for mobile but les see if it applies The tag is applied by using the API Dynatrace.identifyUser(<usertag>); where <usertag> is e.g. the users email address or a user id which you want to tag the session of a user.”
Note : this system wont let me add React as a label?
The following labels are not available here: React
thanks
Ed
Hi @edward_prinsloo
I can’t understand if you mean React (web JavaScript) or React Native (Mobile).
However, I’m telling you about both.
For Web:
There are several alternatives to configure the UserTag in those cases:
Options like:
- Css selector
- JavaScript variable
- Meta tag
- Cookie value
- Query string
- Server-side request attribute
For Mobile ( Reactive native) :
@dynatrace/react-native-plugin - npm (npmjs.com)
I hope it’s helpful
thankyou.
Years ago I was told to only use java script, for web pages, as it was the most proficient. I could not get the tag to work as the react coder had made a mistake. It is working now. We mostly use angular and so react was new to me.
