We have noticed on of our applications that the path C:\AI_RecycleBin is consuming too much space on C Disk.
We took a look into it and it seems to belong to Dynatarce agent.
Does someone have any idea why we have this behaviour and how can we fix it ?
Thank you.
Maybe, you can create a support ticket with OneAgent diagnostics.
Best regards
As per the Dynatrace
this is a known issue with Advanced Installer. As a workaround, the One Agent installer clears the AI_RecycleBin at the end of the installation. However, this cleanup might not work if the installation fails in an early stage, such as in the case of a missing MSI package in Windows Installer Cache.
Please delete the folder. And if it continues . Then the OA installation is corrupt and needs to be redeployed.
For more information, please check the following docs
· AI_RecycleBin
· https://community.dynatrace.com/t5/Open-Q-A/Dynatrace-OneAgent-Windows-1-245-174-msi/m-p/241000
Abid
