Hi All,
Somehow local admin account for my Dynatrace Managed cluster has been removed. Admin user is not even visible in user account list. Is there a way to recover the local admin account.
Email ID used against admin account no longer exists.
Himanshu
I would recommend putting in a support ticket on this just to be sure that you get a resolution to this.
You can remove admin account from CMC - this is usually done for the security reasons to force authentication only via LDAP/SSO.
If admin account was removed, then only Dynatrace ONE can restore the account.
