Recreating Native Problem Chart Behavior in DQL (Active Problems Over Time)
Hi everyone,
I’m trying to recreate the problem chart from the Problems menu using DQL, but I’m struggling to match the behavior of the native visualization.
Current approach:
fetch dt.davis.problems
| makeTimeseries count(), by: {event.status}
Current result:
The problem only appears as a single bar at the timestamp field.
Expectation:
I want the problem to behave like the native Problems chart:
  • The bar should start appearing from event.start
  • The bar should continue to reappear based on the selected interval
  • Example:
    • If interval = 5 minutes
    • And the problem event.status is still OPEN (or event.end is null)
    • Then the same problem should continue contributing to every 5-minute bucket until it is CLOSED
So essentially I’m trying to calculate “active/open problems over time”, not just “problem creation count”.
Has anyone successfully recreated this behavior in DQL?
Is there a recommended approach/pattern for expanding problem duration across time buckets?
Thanks!
Hello @zaidanrizq!
I’m not sure if got right, but I think you want something like this:
If it’s, you can use this Json below and then use as a dashboard, I made comments on the dashboard so you can understand better:
  "tiles": {
    "0": {
      "content": "# Problems over time\nThis dashboard recreates the Problems chart behavior by counting problems across their active duration, from `event.start` until `event.end` or `now()`.",
      "type": "markdown"
    "1": {
      "davis": {
        "davisVisualization": {
          "isAvailable": true
        "enabled": false
      "description": "Counts each problem in every interval where it was active.",
      "query": "fetch dt.davis.problems, from: toTimestamp($dt_timeframe_from) - 2h, to: toTimestamp($dt_timeframe_to)\n| filter event.start <= toTimestamp($dt_timeframe_to)\n| filter coalesce(event.end, now()) >= toTimestamp($dt_timeframe_from)\n| makeTimeseries problems = countDistinct(display_id),\n    by: { event.status },\n    interval: 5m,\n    spread: timeframe(from: event.start, to: coalesce(event.end, now()))",
      "querySettings": {
        "defaultSamplingRatio": 10,
        "defaultScanLimitGbytes": 500,
        "enableSampling": false,
        "maxResultMegaBytes": 10,
        "maxResultRecords": 1000
      "title": "Problems over time by status",
      "type": "data",
      "visualization": "barChart",
      "visualizationSettings": {
        "autoSelectVisualization": false,
        "chartSettings": {
          "legend": {
            "position": "right"
        "coloring": {
          "colorRules": [
              "colorMode": "custom-color",
              "comparator": "=",
              "customColor": "#C91313",
              "field": "event.status",
              "type": "string",
              "value": "ACTIVE"
    "2": {
      "davis": {
          "isAvailable": true
        "enabled": false
      "description": "Same logic without splitting by status.",
      "query": "fetch dt.davis.problems, from: toTimestamp($dt_timeframe_from) - 2h, to: toTimestamp($dt_timeframe_to)\n| filter event.start <= toTimestamp($dt_timeframe_to)\n| filter coalesce(event.end, now()) >= toTimestamp($dt_timeframe_from)\n| makeTimeseries problems = countDistinct(display_id),\n    interval: 5m,\n    spread: timeframe(from: event.start, to: coalesce(event.end, now()))",
      "querySettings": {
      "title": "Total problems over time",
      "type": "data",
        "chartSettings": {
          "legend": {
            "position": "right"
  "variables": [],
  "annotations": [],
  "settings": {
    "defaultTimeframe": {
      "enabled": true,
      "value": {
        "from": "now()-2h",
        "to": "now()"
  "layouts": {
    "0": {
      "h": 3,
      "w": 24,
      "x": 0,
      "y": 0
    "1": {
      "h": 8,
      "w": 24,
      "x": 0,
      "y": 3
    "2": {
      "h": 8,
      "w": 24,
      "x": 0,
      "y": 11
  "importedWithCode": false,
  "version": 21
I hope it helps you 😊
It worked as expected, Thanks a lot!
You’re welcome, glad to help 😁
