Reference to XHR query string parameters?
I would like to implement user action naming rules that are based on the value of a query string parameter of an XHR request. Unfortunately it does not appear that query string values are available for XHR actions. Is this correct, or am I overlooking something? If access to the query string parameters is not available, are there plans to make them so?
At this point, I dont think you can - I checked a few routes and didn’t find the XHR option there. I would recommend tossing in a RFE and the Dynatrace Developers can look into your specific use case! Let me know if you need a hand creating one.
Stay safe and healthy.
-Chad
