We’re trying to adapt the value of an auto-tagging rule.
In order to do so, we’d like to skip the first X characters and then return the remaining part of the string.
(this because Dynatrace does not seem to be able to deal with multiple capturing groups, which was the first attempt)
Current code, working via regex101: build, test, and debug regex
^.{7}\K.+
But after all, Dynatrace isn’t able to deal with the ‘\K’ part.
Are there any other solutions?
So, for example: the regex rule applied on
AppPoolTaggingRule
should return
TaggingRule
Thanks for your help,
Jan
