Dear friends,
I am building a dashboard version based on the “Release Comparison Insights” dashboard, but focusing on a slightly simpler approach and strictly within the Kubernetes context, using metrics and logs. I used the standard labels from the documentation (Version detection methods — Dynatrace Docs), but I am having trouble retrieving OOM and container restart metrics for the deployment pods.
I would appreciate your help in understanding what is needed to populate the container restart and OOM metrics. Ideally, I would like to display both metrics in the same tile, though separate tiles are acceptable if that isn’t possible. I am also open to other improvements, provided they remain within the scope of Kubernetes metrics/logs (I plan to add traces at a later stage).
All the DQL queries were created with the help of Assist, so I am not sure if they were created in the most optimal way; I believe there is room for fine-tuning or refinement.
Release Comparison Insights - Visão Kubernetes Labels V2.json (27.9 KB)
Thanks for sharing the dashboard. I tested it against a workload with two releases, one OOM-killing and one healthy.
A few glitches in it:
- The “previous release” lookup was unreliable. It picked one ReplicaSet (
limit 1) and ranked versions by Smartscape first_seen, which isn’t the ReplicaSet creation time. A version with several ReplicaSets was only partly matched, and the “previous” version could be the wrong one.
- Build tiles: they used undefined variables (
$latest_build, $previous_build).
- CPU Throttle % reached 1,000–2,000%:
cpu_throttled is millicores of unmet demand, so dividing it by the limit isn’t a percentage.
What’s changed:
- Versions are ranked by
deployment.kubernetes.io/revision, and all ReplicaSets of a version are matched.
- Build tiles are now Revision tiles.
- CPU throttling is
100 * throttled / (usage + throttled), which stays between 0 and 100%.
Patched JSON attached. If you’d rather see a flat 0 on healthy releases than “No records”, that needs a zero-fill in the query. And these are just guesstimated … as I don’t 100% know what you wanted. But hopefully gives some ideas for further enhancements.
Release Comparison Insights - Kubernetes Labels V2 (patched).json (34.5 KB)
Sorry for the delay in responding and thank you for the help. Things have improved significantly following your adjustments, and I find the dashboard more reliable now—this is exactly what I was hoping to work with initially.
I’ve already been asked for an additional improvement, which I’ll try to address using Assist; if I run into any further difficulties, I’ll follow up here.
Thanks!
