Hello Plugin Developers!,
I’ve recently developed a plugin (AG 1.0) that depends on another 3rd party library (pyexasol). When executing this plugin on a Linux AG with NO system-wide python installation the plugin will fail with this error:
2022-06-23 13:45:04.009 UTC ERROR [Python][14869391503175389801][][140106916681472][ThreadPoolExecutor-0_12] - [query] Traceback (most recent call last):
File "/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.exasol/dynatrace_activegate_exasol_plugin.py", line 66, in query
db = pyexasol.connect(dsn=self.connectionstring, user=self.username, password=self.password, encryption=True, fetch_dict=True, websocket_sslopt={'cert_reqs': ssl.CERT_NONE})
File "/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.exasol/pyexasol/__init__.py", line 68, in connect
return ExaConnection(**kwargs)
File "/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.exasol/pyexasol/connection.py", line 186, in __init__
self._login()
File "/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.exasol/pyexasol/connection.py", line 601, in _login
'clientOs': platform.platform(),
File "/opt/dynatrace/remotepluginmodule/agent/plugin/python3.8/platform.py", line 1206, in platform
libcname, libcversion = libc_ver(sys.executable)
File "/opt/dynatrace/remotepluginmodule/agent/plugin/python3.8/platform.py", line 193, in libc_ver
with open(executable, 'rb') as f:
IsADirectoryError: [Errno 21] Is a directory: '/opt/dynatrace/remotepluginmodule/agent/lib64'
Basically what happens is that the external library at some point calls sys.executable to get the python interpreter binary path (for whatever reason) and some python meta-information.
In case there is no python installed it seems that this call returns a path to the remoteplugin library directory and then fails with with IsADirectoryError when trying to determine the libc version.
My guess is that this has to do how the runtime is called/embedded within the remotepluginmodule. Does anyone with some knowledge around the embedded python is doing this know why this would happen and how this could be prevented?
Cheers!
