Hi Team, Need your help again ![]()
Question 1.
I have 2 servers where firewall ports are opened (9999) i have installed OneAgent on both server with setting up the network zone and set server active command.
Now issue is that if i am installing OneAgent with set server AG command then i am not getting data on Dynatrace.
If set server is not used, I am getting the data on Dynatrace as network zone have their own active gate.
Question 2.
I have installed one agent on 100+ servers with set server AG command and selected network zone setup,
But i want to remove the active gate as data is not coming on Dynatrace, only keep Network zone which have AG setup already.
I tried removing using below commands but getting error, how I can fix this?
oneagentctl.exe --set-server=“”
oneagentctl.exe --set-server=Default
