Remove host that is not avaible anymore
I have a host (Windows 2016 server) that had the OneAgent installed and the server is not available any more, this means I can´t uninstall the agent.
How do I remove the host from the system?
So I am assuming that the host was decommissioned? Never the less, you can edit your hosts by going to Settings>Monitoring>Monitoring Overview>Hosts
After a few days of the host reporting as offline, Dynatrace will no longer alert on it too.
Yes, ok thank.
So I can´t remove my self now?
If you dont have the option on the list below, you might not be able to. but after 3 days it should drop out. We had this issue as well where the server team did not communicate decommissions and as a result, we would be alerted that the hosts were no longer responding or being monitored.
Ok, Thanks.
I do have the option, I would just like to a “Delete” option.
Thanks for the help
