I have arrays that contain a lot of null values but i would like to replace them not with a single value but instead with whatever previous value in the array is not null, is this possible in DQL?
Unfortunately we do not have such array function yet, but there is a trick which can be used if you know maximum number of consecutive nulls in your array.
If you can have max 2 nulls in row, query could look like this:
data record(a=array(1.0 ,null, 2.5, 3.0, null, null, 1.1))
| fieldsAdd a = if( isNotNull(a[]), a[], else: arrayMovingMin(a, 2)[] )
If more, you need to repeat last command more times.
but:
Thanks for the answer, I can’t know how many consecutive NULL i will have ahead of time but at least i have an idea of a different solution and i know the function does not exist
Friend showed me this solution not having this limitation:
data record(a=array(1.0 ,null, 2.5, 3.0, null, null, null, 1.1))
| fieldsAdd va=record(a=a[], i=iIndex())
| expand va
| fieldsAdd fixedValue = if(isNotNull(va[a]), va[a], else: arrayLast(arrayRemoveNulls( iCollectArray( if(iIndex() < va[i], a[])))))
| summarize a=collectArray(record(va[i],a=fixedValue))
| fieldsAdd a=arraySort(a, direction:"ascending")
| fieldsAdd a=a[][a]
credits go to @AustinSabel
@SimGiants92 , can you tell us more about the need behind this operation? In what situation do you need it. I think there may be a value in having dedicated utility function doing it in one step.
Thanks for the answer!
In my case it is specifically for anomaly detection, i want to trigger an alert if every datapoint is below a certain threshold for an hour. But if some of the values are NULL within that hour the alert does not trigger. I can just assume NULL values are in breach of the threshold by forcing them to be a specific value, but then it gives a graph going up and down (but it still works)
