Resolve “No Module Named cx_Oracle” Error in Dynatrace Extensions
The user needs to be set during installation using the USER parameter. The service to restart is remotepluginmodule.service
Okay Mike. The problem was solved.
What you suggested was correct, I hadn’t done one of the steps, which is systemctl daemon-reload
after that, my plugin is OK.
Thank you very much for your help in this case.
No worries. You picked one of the most complicated libraries to use with an extension. It took quite some time for us to figure out how to use it correctly so don’t be discouraged.
