Hi, Dynatrace Community.
I’m searching for some help with a problem with the MySQL Monitoring tool. I’ve installed ActiveGates and OneAgent executables but when I try to add a new endpoint with this extension, I’ve recieved the error message: “Error(No module named ‘cryptography.hazmat.bindings._openssl’)”.
I checked the directory’s extension (from the ZIP file) and it’s right, it doesn’t have a file with this name, so I’m not sure if this is a problem of a missing file or a missing directory.
That’s why I’m looking for help.
P.D.
I follow the installation instructions from this link: Extensions — Dynatrace Docs
Hi Victor_AT03,
Can you please open a support ticket and mention my name - david.mass@dynatrace.com. In the support ticket can you please also upload the ActiveGate logs? You can collect them by going to the Dynatrace UI → Deployment status → ActiveGates → Select the ActiveGate that is running the extension and clicking Run ActiveGate Diagnostics → Enter in a description and Start Analysis. After it collects everything you can download the zip file.
David
Hi, David.
I’ve just created a ticket with this ID: #31345.
Hello @Victor_AT03
kindly check the configured modules in custom.properties file.
I believe if it’s requiring an extended level of troubleshooting you can proceed with support of try:
- Remove the extension
- update your environment.
- install the extension again.
- ensure the AGs are properly connecting to the designated instances.
- review the configuration properly.
- Hopefully it will work.
