I am trying to create a workflow using a loop task which has a input from a DQL query. The loop task is referenced inside a HTTP request task . I keep getting the below error, looking for advice on what is that I am missing here please
Loop task
Error
Unhandled failed task(s) during workflow execution:
monitoringmode_update:
Error evaluating loop expression. Undefined variables: records.
Hey @p_devulapalli ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you!
I am still having the same issue with my workflow. I have a json response from a 3rd party api that has a listagent states. I am looping through the agentStates section of the json response and attempting to use a “Ingest Business Event” step to ingest each item in the list as its own event.
This is the input for the list: {{result(“get_nice_agents”)[“agentStates”]}}
- Dynatrace validates this is a list
The variable name I am setting for each iteration is agentState. In my “Ingest Business Event” step I am using
{{ _.agentState }} | to_json
To reference the variable value of each iteration.
I get the following error:
ingest_business_event_2:
Error evaluating loop expression. Undefined variables: agentStates.
The only place I am referencing “agentStates” is in the loop list definition.
