Restart Web server in case a problem is occured
We want to trigger a command automatically to restart the application service (like apache) when a host doesn’t make any http response. To do so, we need to execute a command on the host.
You can already achieve this by configuring a auto-remediation using alerting profiles.
You can ready here : Problem alerting profiles — Dynatrace Docs
Here’s a similar question: https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/240675/problem-auto-remediation-with-dynatrace.html
Here’s a blog post for SNOW integration: Leveraging ServiceNow and Dynatrace
I’m sure you can find a lot of different materials about this.
In short:
1. Set up an alerting profile and define either a custom event or use existing one.
2. Use Ansible Tower, SNOW, Jenkins, Keptn or whatever else that works for you to trigger a desired job - e.g. restart a host XYZ
3. Bind the notification of the event to remediation action.
It’s helpful for me, thank you!
Can I use Ansible instead of Ansible Tower?
No, you cannot. Ansible is just a “scripting” language and doesn’t have any REST API that Dynatrace can communicate with. But you can use Jenkins or other CI/CD you have that triggers the ansible.
I understand. Thank you for confirmation!
I wanted to achieve self-healing without those tools.
Can I request this?
Hello, I found same question! :
Can I do this?
You can request anything… but IMHO it is not feasible.
That’s exactly what I write - you need sth to receive REST calls from Dynatrace. No matter if this is :
- Ansible Tower
- AWX
- Ansible Python/Webhook … whatever else..
- You can even have your own webserver that will trigger Ansible.
I’m sorry I didn’t understand well…
Is it possible to share with me about Ansible Webhook..?
https://github.com/scalr-tutorials/ansible-webhook
Thank you for your kindly support. I will check.
