I want to Return 0 value for summarize count instead of “There are no records” by DQL for custom charts in Latest Dynatrace Dashboard
Dear @DeivanaiSekar
PFA related example for reference and applying the required changes.
- For full details and related examples feel free to visit DQL metric commands — Dynatrace Docs
Hoping it helps.
BR,
Peter.
Hi Peter,
Thanks for your inputs!
But I am using Fetch logs command with summarize count for filtered value.
can you share a sample of your current configs, Thanks.
Hi @DeivanaiSekar
We have experienced such case and generally Dynatrace will show “there are no records”.
- 0: won’t be calculated by any mathematical calculations that’s why the highlighted message being shown through the UI.
BR,
Peter.
