I’m currently using this query to reuse the same custom metric at different time intervals to populate table data in my dashboard. However, I’d like to simplify the query and reuse a variable multiple times with different conditions in DQL. Is there a better way to structure this?
timeseries METRIC_A_approved = sum(
`custom.app-metrics.transaction.data`,
scalar: true,
filter: {
txType == “TypeA” AND
(responseCode == “0” OR responseCode == “00”) AND
(isNull($Entity) OR $Entity == “” OR entity == $Entity)
), by: { entity }
| join [
timeseries METRIC_A_total = sum(
scalar: true,
filter: {
), by: { entity }
], on: { entity }, fields: { METRIC_A_total }, kind: outer
| join [
timeseries METRIC_B_approved = sum(
scalar: true,
filter: {
txType == “TypeB” AND
), by: { entity }
], on: { entity }, fields: { METRIC_B_approved }, kind: outer
| join [
timeseries METRIC_B_total = sum(
scalar: true,
filter: {
), by: { entity }
], on: { entity }, fields: { METRIC_B_total }, kind: outer
| join [
timeseries METRIC_B_approved_subgroup = sum(
scalar: true,
filter: {
(categoryCode in [“1001”, “1002”, “1003”, “1004”, “1005”]) AND
), by: { entity }
], on: { entity }, fields: { METRIC_B_approved_subgroup }, kind: outer
| join [
timeseries METRIC_B_total_subgroup = sum(
scalar: true,
filter: {
), by: { entity }
], on: { entity }, fields: { METRIC_B_total_subgroup }, kind: outer
| join [
timeseries METRIC_B_approved_domestic = sum(
scalar: true,
filter: {
categoryCode == “2001” AND
), by: { entity }
], on: { entity }, fields: { METRIC_B_approved_domestic }, kind: outer
| join [
timeseries METRIC_B_total_domestic = sum(
scalar: true,
filter: {
), by: { entity }
], on: { entity }, fields: { METRIC_B_total_domestic }, kind: outer
| join [
timeseries METRIC_B_approved_crossborder = sum(
scalar: true,
filter: {
categoryCode == “2002” AND
), by: { entity }
], on: { entity }, fields: { METRIC_B_approved_crossborder }, kind: outer
| join [
timeseries METRIC_B_total_crossborder = sum(
scalar: true,
filter: {
), by: { entity }
], on: { entity }, fields: { METRIC_B_total_crossborder }, kind: outer
| fieldsAdd
Rate_A = if(coalesce(METRIC_A_total, 0) == 0, 0, 100 * coalesce(METRIC_A_approved, 0) / coalesce(METRIC_A_total, 0)),
Rate_B = if(coalesce(METRIC_B_total, 0) == 0, 0, 100 * coalesce(METRIC_B_approved, 0) / coalesce(METRIC_B_total, 0)),
Rate_B_subgroup = if(coalesce(METRIC_B_total_subgroup, 0) == 0, 0, 100 * coalesce(METRIC_B_approved_subgroup, 0) / coalesce(METRIC_B_total_subgroup, 0)),
Rate_B_domestic = if(coalesce(METRIC_B_total_domestic, 0) == 0, 0, 100 * coalesce(METRIC_B_approved_domestic, 0) / coalesce(METRIC_B_total_domestic, 0)),
Rate_B_crossborder = if(coalesce(METRIC_B_total_crossborder, 0) == 0, 0, 100 * coalesce(METRIC_B_approved_crossborder, 0) / coalesce(METRIC_B_total_crossborder, 0))
| filter not(isNull(entity) or entity == “”)
| fieldsAdd
Entity = entity,
A.Total = toLong(coalesce(METRIC_A_total, 0)),
A.Rate = concat(toString(round(coalesce(Rate_A, 0), decimals: 2)), “%”),
B.Total = toLong(coalesce(METRIC_B_total, 0)),
B.Rate = concat(toString(round(coalesce(Rate_B, 0), decimals: 2)), “%”),
B.Total.Sub = toLong(coalesce(METRIC_B_total_subgroup, 0)),
B.Rate.Sub = concat(toString(round(coalesce(Rate_B_subgroup, 0), decimals: 2)), “%”),
B.Total.Dom = toLong(coalesce(METRIC_B_total_domestic, 0)),
B.Rate.Dom = concat(toString(round(coalesce(Rate_B_domestic, 0), decimals: 2)), “%”),
B.Total.XB = toLong(coalesce(METRIC_B_total_crossborder, 0)),
B.Rate.XB = concat(toString(round(coalesce(Rate_B_crossborder, 0), decimals: 2)), “%”)
| fields Entity, A.Total, A.Rate, B.Total, B.Rate, B.Total.Dom, B.Rate.Dom, B.Total.XB, B.Rate.XB, B.Total.Sub, B.Rate.Sub
| sort A.Rate desc
