Rubrik Backup Monitoring
Does anyone have implemented Rubrik backup monitoring integration with Dynatrace SaaS?
(ie) Monitoring integration with Rubrik environment and generate alerts and dashboard for backup failures, long running backups, etc. As per checking in Hub, there is no Extensions for Rubrik.
Any one ?
This is something we would like to see as well, please upvote this RFE:  https://community.dynatrace.com/t5/Product-ideas/Rubrik-Security-Cloud-Extension-Request/idi-p/298006#M57249
Thank you @nealE . Done with upvote.
Please let me know if you develop any custom API based custom extensions in the meantime.
