Hum hum .. We have web request/xhr involved for each click but nothing indicate the user has clicked and where.
In the old version of dynatrace (appmon), we used to have “User A clicked on Menu Women” so we could reproduce issue easier.
Currently with my angular instrumentation, I don’t see where the user has clicked so it is complex to reproduce and reduce the interest of Dynatrace RUM. This is why i think this is something on my side which is not correctly setup.
Ah I think I get what you want now. The name schema is indeed different from AppMon to dynatrace. Dynatrace names XHR actions after the triggering XHR request not the user input like in AppMon.
But you can recreate that behavior, go to: Application Settings → User Acions → Naming Rules for XHR Actions and create the following rule:
Naming patter:
{userInteraction (default)} on {elementIdentifier (default)} on Page {pageUrlPath (default)}
For multi language applications you might get a lot of different user action for the same button click, which would be bad for baselining.
The XHR URL is a better default for grouping the user actions together correctly, also it might not be as readable as the user interaction in some cases. Luckily the new User Action Naming Engine is very flexible so you can satisfy all the use cases depending on the application.
