Has anyone managed to get Auto Injection to work on Azure Web App services?
In my case I have a:
Dotnet - v4.0 runtime stack
which I believe should be a supported technology for auto-injection Technology support — Dynatrace Docs
I followed https://community.dynatrace.com/t5/Dynatrace-tips/PRO-TIP-RUM-injection-check-tips/td-p/173825
And the x-dthealthcheck header returns “CAPTURING_OFF_APP_CONF”.
Hi @xchre
AFAIK .Net is not able to inject JS agent to pages
technologies listed in Technology support - Real User Monitoring - Web servers and applications
HTH
Yos
This means the web application is disabled in Dynatrace. You need to enable it. But it means the rum sensor is there and so the autoinjection is possible. Maybe it falls to the my web application which you have disabled?
