RUM default activation
Is there a way to install the agent in Full stack without the RUM activated ?
Best regards,
Jean-Michel Béranger
If you do not create any rule by yourself to create your application with RUM information, it will go to “My Default Application”. You can disable that default application.
And then, create your own rule base on domain or URL to split it from default application and enable RUM.
You can Check application detection rules.
Best regards
