ruxitagentjs_ICA2NVfghjqrux_10259230221142207.js
Does anybody know what the options/flags mean in the script name?
KR Henk
I don’t believe we publish the featurehash anywhere publicly. Is there something specific you are interested in?
Hi @henk_stobbe
In the past we have play around with the Async web requests and SPAs and Content capture (i.e. switch them on and off) and got a bit of idea which setting belong to which sign between the ruxitagentjs_ and _10259230221142207.js
Sorry but I did not find the list we had that time.
The left part holds the version - sub version - date - time  - release (10 - 259 - 230221 - 1142 - 207)
HTH
Yos
Do you know the N & S?  please  (-;
KR Henk
Hello Yosi,
when we do manual injection we use zero instead of that piece of the string with version etc.
And that works fine
Henri
S was Speed Index, but is now inside another module, so I wouldn’t expect to see it anymore.
N is content capture> Visually complete (which is actually where Speed Index was moved)
Hi @henridb
Agree, for manually injection you can change the name of the JS agent to what ever you like.
The naming convention is only for helping support guys to understand what are the JS agent version and capabilities.
Yos
