Salesforce integration with Dynatrace
Wanted to have information regarding possibility Salesforce integration with dynatrace so that i can monitor application servers deployed on Salesforce Cloud. On help.dynatrace.com i can see integration possible through PaaS solution but that is limited to AWS and Cloud Foundary. Share some valuable link if this integration possible and till what level we can monitor Application servers deployed in salesforce.
With Dynatrace real user monitoring you can monitor SaaS applications either by using our Real user monitoring or if you can add a JavaScript tag to a template, you can use our normal real user monitoring
Hi Alexander.
Is possible to monitor an API from salesforce? metrics like response time of this APIs?
Cesar.
Hi Cesar, there will be something delivered in this area, it is an item on the roadmap and is not too far away.
Gary
Hi @Alexander S.
Could you please help me with the steps to add JS tag to template, It would be very useful for us for RUM SAAS application.
@Gary S. - Did you hear anything on API side?
Suraj Gupta
Hello. Where are we on this deliverable? Notes seem to have gone silent since May 2018.
Hello, just coming across this thread, there is an awesome Salesforce Extension that our Extensions Services Team built that can be leveraged to gain insight into User Experience for Salesforce. Please reach out to your account team to evaluate it and determine pricing.
Happy Dynatracing
Lawrence Cuneaz
Dynatrace Solutions Engineer
