Sample Oracle DB insight dashboards
do you have an Oracle DB insight dashboard that you are currently using? Can you share? Or where can I find it?
Regards.
I’m not sure what the current rules for sharing this type of information might be. I might be able to help. Probably @MaciejNeumann , could we have a hint on the best way to eventually share this type of information?
Attached is the Dashboard JSON for one that I use with my current customers. It should give an idea of how we can chart out the various additional metrics that are available with Oracle Insights.
Let me know if you have any additional questions.
-Ryan
Oracle Insights.zip (1.4 KB)
As long as there is no confidential information in it (like passwords, environment IDs, API keys, IP addresses, or name of your clients), sharing it in the Community is totally ok šŸ™‚
Hi
Thanks @ryan_ott but I don’t see how to download the attachment  šŸ¤”
Is it only me that is so blockhead?!
Yos
You should be able to see ā€˜Oracle Insights.zip’ in my original reply, and click to download.
I was also unable to download, but I saw the zip file. I checked the HTML source code and was able to download afterwards. Maybe someone else can confirm this?
Hi @ryan_ott
We can see it
But there is no download option šŸ¤”
Yos
It is strange - I don’t see an option to download directly now either… As @AntonioSousa mentioned below, it seems you are able to directly visit the link in the source code to start the download.
Here is the link: https://community.dynatrace.com/pssft35649/attachments/pssft35649/Dashboarding/1875/1/Oracle%20Insights.zip
Let me know if that works.
-Ryan
Same here. I got the link from the source code, so I could download the file.
I’ve found the issue with downloading the attachments and fixed it - now you should be able to download it correctly, directly from @ryan_ott post šŸ™‚
Thanks @MaciejNeumann now downloading works as a charm !!!
Thank you. Great work.
cool stuff, thx for sharing!
Just imported it into our test system - one note - you might want to use heatmaps to do the first one instead. In DT 1.232 (heatmap will hit the stage with 1.230) would look like…
That is super cool!
Thanks. This is really great!
Hi dear DT community,
Thanks for this Dashboard that is showing pretty much already all the metrics we would like to see.
Nevertheless, Im facing small issue : when I try to add dynamic filter on the dashboard, by custom dimension, then custom device (I would like to be able to filter and see one by one each of  my oracle databases with Oracle insight configured)
But this is not working, when I choose my filter , so one of my custom device, dashboard still showing metrics for all oracle database with oracle insight configured, not only the one filtered…
Maybe some of you faced the same issue?
Would you be able to help me with that?
Thank you a lot in advance for any advice.
Thx
Best regards
Antoine
Just to tell you I was able to achieve my requirements. by using the ā€œupgraded chartsā€ and adding in each tile the ā€œcustom deviceā€ filter.
