Hello guys,
I’m trying to request a Bearer Token via n8n workflow using the oAuth Client, and everything looks good on the Reqs,
For example the response from the oAuth Client is:
"scope": "app-engine:functions:run storage:logs:read mcp-gateway:servers:invoke mcp-gateway:servers:read",
"token_type": "Bearer",
"expires_in": 300,
"access_token": "eyJhbGciOiJ.RestOfTheToken",
"resource": "urn:dtaccount:numbersHere"
The interesting part comes when I try to use the Token, it says that miss some scopes (the ones I sent), and when I decode to check the scopes they’re empty… I already checked the permissions and I also used these credentials before in another tool.
Any ideia?
