Script languages when setting up workflows
When setting up workflows, which scripting languages can be used?
I had seen only TypeScript per now, but others will be included.
Best regards
Besides the extensibility provided by Javascript and HTTP requests (webhooks), AppEngine allows the use of SDKs to extensively interact with Dynatrace. One example of this is our open-source Automation Workflow Creator.
The advantage: You can directly reuse the same ad-hoc scripting code to build your own reusable workflow action (for low/no code usage) in your environments.
