So, possibly a proxy issue - does the ActiveGate have the same proxy settings as the ActiveGate? You can see how to set them here. There is a section at the bottom of that page for if you are using proxy PAC files.
Also, you mention credentials. Do you need to add login details here?
If that doesn’t help, I recommend that you ask on chat or raise a ticket as we would need to look at the Monitor in further details.
