Hi There,
I am working on migration task on our Custom DB Query written in python on Dynatrace managed using extension 1.0 to Extension 2.0 - SQL Data Source. Though it is successful, I wasn’t able to define it as group and sub-group in our scenario. Seeking for a help in what SQL query should I define in the group level, in case I re-define 2nd, 3rd and 4th group in below example as a sub-group. Such that I can make use of same extension up to 100 metrics. Otherwise, I will be limited to 10 metrics only (assume if only one metric defined against each sql query in a group and no sub-group exist). Note, where possible I tried to merge multiple queries into one single queries. In below example, assume I cannot merge queries into one single sql statement. I do make use of dimension and multiple keys where possible. These queries are specific to application tables and not any generic that can be used across the database or server.
sqlServer: - group: GroupDBOne_ServerOne featureSet: FeatureSetOne_TableOne query: SELECT COUNT(*) AS ColumnO1 FROM TableO (NOLOCK) WHERE condition metrics: - key: key.colO1 value: col:ColumnO1 type: gauge interval: minutes: 15 timeout: “120” - group: GroupDBTwo_SeverTwo_1 featureSet: FeatureSetTwo_TableOne_1 query: SELECT COUNT(*) AS ColumnT1 FROM TableT (NOLOCK) WHERE ColumnT LIKE’TextOne’ metrics: - key: key.ColT1 value: col:ColumnT1 type: gauge interval: minutes: 15 timeout: “120” - group: GroupDBTwo_SeverTwo_2 featureSet: FeatureSetTwo_TableOne_2 query: SELECT COUNT(*) AS ColumnT2 FROM TableT (NOLOCK) WHERE ColumnT LIKE’TextTwo’ metrics: - key: key.ColT2 value: col:ColumnT2 type: gauge interval: minutes: 15 timeout: “120”
- group: GroupDBTwo_SeverTwo_3 featureSet: FeatureSetTwo_TableOne_3 query: SELECT COUNT(*) AS ColumnT3 FROM TableT (NOLOCK) WHERE ColumnT LIKE’TextThree’ metrics: - key: key.ColT3 value: col:ColumnT3 type: gauge interval: minutes: 15 timeout: “120”
Thanks and Regards,
Darshan Doshi
