Roeir5
November 21, 2024, 2:54pm
1
Hy
how I can create dashboard (metric formula) to show how many oneagent(os) connected to each ActiveGate in cluster?
i have 2 servers in network zone and i want to understand if load balance work well
thanks
ps: amount per tenant exist in dashboard - its ok
Hello @Roeir5
In addition to the direct answer provided by @AntonPineiro
PFA for detailed info:
Hoping it adds value.
KR,
Peter.
Hi @Peter_Youssef & @AntonPineiro
As far as I understand, @Roeir5 is looking for a way to check currently how many hosts are connected to each AG as can be seen from deployment status --> AG
IMO there is no metric that can be utilize for that , but will be happy to learn that I’m wrong :nerd_face:
Yos
Roeir5
November 24, 2024, 9:06am
5
I tried to use this query to find the value as @Yosi_Neuman describe in deployment status --> AG ,but value is not compatible with data from metric
dsfm:active_gate.communication.agent_modules.connected:splitBy(“host.name”):sort(value(auto,descending)):limit(20)
